I've changed telnet to SCP when backing up my swtich configurations. SSH login to switch with putty works fine. So configuration seems to be ok.
Also if I test the login settings that I've configured to switch in Orion, they seems to work too, because it gives "test successful" message. (I mean if I go to node --> edit node --> NCM properties --> test. So node settings in Orion are correct.)
But when I try run a backup job that has worked before, those devices that I've changed to use SCP instead of telnet, giving "passwork not correct"-error. Old telnet using devices are ok.
If I try to download config directly from configuration management (not from jobs), it gives error "bad password", but when I go to suggested setup page "fix connection in device template" and run "test device access" from there, it is successful.
I've noticed that maybe I have to do something to SCP server in Orion too. So I created same user account there. That did something, because now it seems like ONE of two switches (using exactly same connection profile!) is showing in SCP server log. It shows "user xxxxx from ip xx.xx.xx.xx uploading file to "shdhioege.config" (what the hell is that filename?!?) but when I go to SFTP folder, it's still empty.
So what is really a problem, as it obvously isn't in connection profile?
This is my first time using SSH, so I'm n00b and problem can be anything!
