Hello....
Is the Network Insight module already included with NCM??
Or do I need to download and install it???
If I do need to DL and install, when can I get info/help??
Thank you!!
Dennis - As long as you are running v7.8 or newer it will already have both the Network Insight for Cisco Nexus and ASA prebuilt into the software. If you are looking for the views that are shared you need to also have NPM installed. There are help documents here: NPM 12.3 and NCM 7.8 feature: Network Insight for Cisco Nexus devices - SolarWinds Worldwide, LLC. Help and Support NPM 12.2 and NCM 7.7 feature: Network Insight for Cisco ASA firewalls - SolarWinds Worldwide, LLC. Help and Support
In addition to posting on THWACK you also reach out to me directly with other questions.
Thank you....
Just to be clear as long as I have NCM (I have 7.9), Network Insight for both ASA and Nexus would be included??
Thanks again!!
Dennis
Correct v7.9 will have both the functions.
Network Insight for Cisco ASA was introduced in v7.7 and Network Insight for Cisco Nexus was introduced in v7.8, so any versions after their introduction includes the features.
Thank you very much!!
