Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
How to track down a machine
tayhuck
I've run the Solarwinds IP Address Manager and the IP Network Browser and there are a handful of static Addresses that show zero information about them and I don't know how to track down what devices are using those IP addresses. All of our Cisco devices are showing up that way as well, but I just happen to know their IPs.
Any suggestions?
--Taylor
Find more posts tagged with
Accepted answers
All comments
Keyan
If they aren't registered in DNS you aren't going to be able to resolve a hostname for the device. If you are running windows you can always try doing a ping -a, which will try to resolve the name of the device. If that doesn't work, then you will have to either find the owner of the device or track down where it's attatched to your network and trace the cable...and hope it's labeled.
Bryan
Try adding some additional SNMP community strings to your IP network brower. If you know there's an active IP on the network, but your not sure where it's at, use the switch port mapper to isolate the switch and port.
Lockheed Martin
Atlas V Launch Operations
Network Engineer
Network_Guru
Do a search in this forum for "scanner"
Here is one topic with a few answers:
www2.solarwinds.net/.../topic.asp
If you have the EE there is a Port Scanner tool which may help.
-=Cheers=-
NG
pgpf
Run the switch port mapper on some of your switches. It is a fast and easy way to know what IP/MAC addresses are on which switch port. Or, for Cisco switches you can do the following:
If you know the MAC address, log onto a switch on that subnet.
do a 'show mac-address address xxxx.xxxx.xxxx' and if that address is in the table it will show the port the switch knows that address is on.
Do a 'show mac-address interface xxx' to see how many addresses are on that port. If you only see the address in question, you've found the port. If you see many addresses, you know there is a switch, hub, or AP on that port.
Do a 'show cdp neighbor' and you can see if that port has a Cisco device. Log into that device and continue to track down the mac-address location.
I only know Cisco commands.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
