I have gotten this message in solar winds can anyone tell me what this means. The correlations says InsertionIP not equal to Detection IP.
I'd like to help you, but I need more information. What product and version? Where are you seeing this error? A screenshot might help as well.
I currently do not have a screenshot. It is showing up as an Alert in LEM 6.2
Hey Jaime, I'm going to move this into the LEM forum so you can have some technical assistance from those using that particular product. Sorry for the confusion!
Thanks I truly appreciate that
Can you get a screenshot of the message? You should be able to search it out of nDepth.
