On the Credentials Library page (/Orion/APM/Admin/CredentialsLibrary.aspx), there should be an additional column that tells you the number of components that are using that credential. I have several credentials that I think are not being used anywhere, but I can't check to be sure. I would like to delete unused ones, but don't want to break something if someone has set them up. It would also be helpful in case you want to view what credentials are used most often.
