Solarwinds should be able to monitor Cohesity.
This would be excellent!
Thank you,
Cheryl
this seems to be in the wrong category.... solarwinds Backup is a saas backup solution on it's own... I believe you want this in the SAM forum.
However if you know what's needed to monitor Cohesity, you can easily create a SAM Template, maybe even share it with the community
HerrDoktor,
Thanks! If we use SAM templates, what would you monitor? Just asking.
If I wanted to monitor backup jobs through Solarwinds, I don't know if I can use SAM templates.
We are actually own the Cohesity appliances. I am still trying to get compatible OIDs.
From what I read about Cohesity is, that it’s got an API, so SAM‘s API Pollers seem to be a good choice.
if you can work with PowerShell or any other scripts you could utilize SAMs scripting Capabilities.
SNMP could be working, however I find it somewhat limited when it comes to monitoring non Network Equipment
THank you!
@cmatrask @HerrDoktor
Hello, just wondering if you have been able to successfully monitor Cohesity
Hi @farzinx, I am currently monitoring the nodes in the clusters using SNMPv2c.We are monitoring the attached drives, but we are NOT monitoring the network attached storage. For some servers there are more than 640+ network drives.The webconsole is extremely slow!
This needs to be extended to alerts likeError Message: CE00401004 KernelPanic Alert Description: Node 966064694446 with ip XX.XXX.XX.XX crashed from a kernel panic. Alert Cause: Found kernel panic crash dump file. See dump at /home/cohesity/data/logs/crashdumps/127.0.0.1-2024-03-13-19:15:46 on node 966064694446 Reason: Kernel panic - not syncing: Machine check from unknown source
