Hi there,
Orion is pulling the language setting from the OS or the browser and displays the web interface in the respective language automatically.
This isn't the best behavior in all situations and a change is quite involving:
Change Language for your Web-Console - SolarWinds Worldwide, LLC. Help and Support
Change the language settings on your Web Console using the Web Browser - SolarWinds Worldwide, LLC. Help and Support
A link somewhere top right to switch from EN to DE (or any other supported language) would be great, and shouldn't be too complicated to add!
Thanks!
Have my own browser for Orion with the default settings switched to "EN"
Weil Deutsch halt ned immer so dolle übersetzt ist
Darker blues are most often associated with anxiety and depression, hence the common term “feeling blue.” On the flip side, lighter shades of blue are usually considered to be allfinebooksites Get a superior comprehension of the checking basis. Furthermore, plan according to that also. More focuses a specific undertaking contains, the additional time you are encouraged to spend on it.
