In a thread I started called APM: Ability to Copy Component Monitors, I stated that it would be nice to have this ability and that it was not present in SAM 5.2. However I have now discovered where it is and added a comment to that thread about how to access it for anyone interested. My reason for this enhancement request is that the copy takes on the enable/disable property from the source. This means that if you copy the Component Monitor into an active Application Monitor, the new Component Monitor copy immediately becomes active as well. I would rather have the copy disabled by default so that I have time to navigate to the target Application Monitor and change the script options, the threshold settings, etc.
Please consider disabling Component Monitor copies by default.
