Application templates allow for custom Application Views. However all components in all application templates use the same view. These views have widgets that require hard coded max scale value. Applying that max scale is not practical for all components. For example the component might return a percentage for a value between one and a hundred. Other components will return a value in the thousands.
Idea: Allow for custom Application Component Detail views to be assigned within templates, per component.
There is also an idea created HERE. That allows for the max limit to be captured from the component thresholds. Vote on that one too!
