I do not see a standard report where we can specify a machine and return top SQL statements. Does anyone have a report or raw SQL for that? I am on DPA version 12.
Thank you,
David kranes
David,
I assume you mean within a monitored instance, you would like to specify one of the machine names listed in the Machines tab and get a list of Top SQLs. Here is a script that should get you started and you can run it from Management Studio while connected to the DPA repository database.
Notes:
Before running this script, change the following as needed:
DECLARE @DBID varchar(5), @SQL varchar(1000);
SELECT @DBID = ID FROM ignite.COND WHERE NAME = 'AVANTIS'; -- substitute the instance name here
SET @SQL = 'SELECT m.NAME AS [Machine], st.ST AS [SQL Text], sum(sw.QP)/100 as [WaitSeconds]
FROM ignite.CONSW_'+@DBID+'; sw
INNER JOIN ignite.CONM_'+@DBID+'; m ON m.ID = sw.PWMY
INNER JOIN ignite.CONST_'+@DBID+'; st ON st.H = sw.IZHO
WHERE sw.D BETWEEN ''11/01/2018'' AND ''11/28/2018'' -- change date values as needed
AND m.NAME like ''DRICHARDS%'' -- change the machine name as needed
GROUP BY m.NAME, st.ST
ORDER BY [WaitSeconds] DESC';
EXEC (@SQL)
Yes, that is correct. This is great! Can this be turned into a custom report in DPA?
David Kranes
Unfortunately DPA does not have custom report capabilities, so you will have to execute from SSMS or other query tool.
Okay. Thank you for your expertise.
David
