I just completed redrawing three (3) huge maps from Network Atlas maps into ORION MAPS, here are some basic features that I would like to be added to this powerful tool, to make it more powerful.
Features ideas:
* Align Items should be expanded to allow you to select nodes and line them up. Example - a row of Groups (site) names and you want to line them up.
I would rename Align Items to Layer Items.
* A simple line tool is needed, freehand and straight line. Adding arrows at the end would be nice, sometimes this is needed when it is not a circuit but you want to draw a relationship.
* Building objects like in Network Atlas for NOC screen maps with companies with many locations.
* Callout field to place near node that will give NOC Support items (like Support contact numbers) on Mouse Over.
Issues to fix:
* Fix the lag and stopping when trying to drag the node around. I would get about 3 seconds to move it before it would stop, I have to click off and click back on to drag again.
Nice to have:
* Rename Map name from Map menu. https://solarwindsinstancename/ui/maps/management/ checkbox, rename.
* Status of Map: Draft, Pending/Review, Production. This would be good to be able to show people a map and have them know what state the work is in. Maybe color border with status (gray, blue, orange) - Dot in the top left hand corner?
Anything that the popular "MS drawing app" staring with V has that could be rolled into Orion Maps would be appreciated. This is a great tool.
Thank you.
