After the initial installation of Solarwinds NPM on Windows 2016 platform the servers were subject to the security hardening policy and a case opened to review the script used, and was progressed with support in lab conditions with regards to using the results in a post live scenario as per - Case # 00432454.
The process is quite arduous with the file extension filtering amended manually in our test environment. What I am looking for is a feature where this process can be invoked as part of the installation or post installation as a tool or an add-on to the config wizard.
As the products continues to evolve this process for many companies will be a requirement and this would help to enable installation and configure without further complications of breaching security polices.
Clive
