Orion showing hardware detailss incorrect reading of Critical for Cisco 3750x power stack.
Sw1, PS1 Normal, RPS NotExistNormalSw1, PS2 Faulty, RPS NotExistNot Functioning
Sw2, PS1 Normal, RPS NotExistNormal
Sw3, PS1 Faulty, RPS NotExistNot Functioning
Sw4, PS1 Normal, RPS NotExistNormal
But when I do a show stack power detail command everything show correctly
D1-3750x-01#sho stack-power detail
Power Stack Stack Stack Total Rsvd Alloc Unused Num Num
Name Mode Topolgy Pwr(W) Pwr(W) Pwr(W) Pwr(W) SW PS
Powerstack-1 SP-PS Ring 2860 43 716 2101 3 4
Power stack name: Powerstack-1
Stack mode: Power sharing
Stack topology: Ring
Switch 1:
Power budget: 943
Power allocated: 223
Low port priority value: 20
High port priority value: 11
Switch priority value: 2
Port 1 status: Connected
Port 2 status: Connected
Neighbor on port 1: Switch 3 - 6c20.56a0.fa80
Neighbor on port 2: Switch 2 - 6c20.5695.1500
Switch 3:
Power budget: 961
Power allocated: 270
Low port priority value: 22
High port priority value: 13
Switch priority value: 4
Neighbor on port 1: Switch 2 - 6c20.5695.1500
Neighbor on port 2: Switch 1 - 6c20.5655.e700
Switch 2:
Power budget: 913
Low port priority value: 21
High port priority value: 12
Switch priority value: 3
Neighbor on port 1: Switch 1 - 6c20.5655.e700
Neighbor on port 2: Switch 3 - 6c20.56a0.fa80
On a switch configured identical to one above
Power Supply
Sw1, PS1 Normal, RPS NotExistNormalSw1, PS2 Normal, RPS NotExistNormal
Sw3, PS1 Normal, RPS NotExistNormal
D1-3750x-02#sho stack-power detail
Powerstack-2 SP-PS Ring 2860 31 1071 1758 3 4
Power stack name: Powerstack-2
Switch 1:
Power budget: 943
Power allocated: 239
Neighbor on port 1: Switch 3 - 6c20.5657.5100
Neighbor on port 2: Switch 2 - 6c20.5615.d300
Switch 2:
Power budget: 943
Power allocated: 393
Neighbor on port 1: Switch 1 - 6c20.5695.1d80
Neighbor on port 2: Switch 3 - 6c20.5657.5100
Switch 3:
Power budget: 943
Power allocated: 439
Neighbor on port 1: Switch 2 - 6c20.5615.d300
Neighbor on port 2: Switch 1 - 6c20.5695.1d80r statu..
