I would love to have a button to reset the view of the map. It is easy to move it around and play with it, but if you want to reset it to the default zoom value, the only (cumbersome) way is to reload the page...
As well the Orion engine needs to be redesigned from scratch
html5 as the core architecture , then features like thus could be more easily deployed
Just realized it's implemented (Tested in NPM 11.5.2).
DanielleH : Could you change this FR status as "implemented"?
cobrien, could you confirm this FR is implemented and have it tagged as such?
