When visiting the file sharing link with Internet Explorer, a small note is displayed which informs about the 4GB file limit, which is fine. But the user is not informed that this limit is only applicable to Internet Explorer – so the user does not know that it’s possible to circumvent the limit just by using another browser. We would recommend adding a small hint for that, for example like this:
When the user clicks on the link, there should be a list of browsers and their respective max. file size.
Corresponding support case number: #1061338
