Hello,
This is regarding the Top XX Volumes by Disk Space Used function as it's presented in "Home Summary"
In my opinion, the fact that physical memory gets mixed up with fixed disks in the same chart is rendering this function less useful. As a system administrator, you are probably interested in one or the other, perhaps both. But there is no logic in having both contesting for the top 10 or 25 in the same chart. They are not equal severe so to speak.
I'm aware of the filtering options, but they are not available on Home Summary for some reason. That's the page you probably will end looking at most of the times, instead of Top10 where filtering options are available.
Rgrds,
Sizor
