The filtering capabilities of the manage entities page allows me to drill down and select only the group of nodes that I want to look at, but I want to move this group to a different polling engine. I can't drill down this same way in manage nodes.
Having this option on the drop-down command menu would be nice, but (just checking my memory) -- you can still highlight your nodes, bulk-edit properties, and then change the polling engine, right?
Actually yes you can....I did not check the "polling options" check and it was greyed out because of this. Even still though, this is where it should be:
