I would suggest adding a setting where you can define the default polling engine that is listed first in the pull down menu when nodes are added outside of a discovery. This could be a time saver for end-users and also help in the management of where new load is added in the environment if a node is added with minimal effort put into the selection of a poller from the user adding it.
