When using the Custom Properties management tool in the Orion web UI to assign values to application monitor properties, rather than showing the name of the node that the application is assigned to, to tool shows the application ID.
This means a lot of digging around is need to find which application ID is related to each node. It really devalues the usefulness of the toll for application custom properties.
For example see the screen shot below. I needed to set priorities & dist lists for alerts for certains nodes, which is achieved via application custom properties. This view gives me no idea which node I'm setting the CPs for.
