i would like to rate with stars the nodes to make it criticality. for the alerts rules.
so in the top ten i would see the criticaly top ten of much nodes.
so its more important to me the saturation of many cores than many branches.
Regards.
Couldn't you accomplish this with "Custom Properties"?
I would create a custom property called Criticality or Impact or Stars or whatever meaningful moniker. Then you can create a rule based on a custom property which says if "Custom Property 'Criticality' is Greater than or equal to 4" AND ("Node is not equal to UP" OR "Application is Not equal to Up") then send alert.
Hope this helps.
sure this helps, but how to make the more important top 10 in the dashboard?
ill try, thanks
Did you ever get this working?
