We need a stand alone tool for viewing logs on our Orion Server from the various tools installed whether it be SAM, VNQM, NPM, NTA, NCM, SRM. Right now it is nearly impossible for end users to do any good troubleshooting.
The log viewer would read log files from a particular directory or you could add/remove directories depending on where the logs may be stored.
The log viewer would allow you to filter on any keyword, or severity level.
Logs would flow through a top window. You would need a start and stop button. You would also need to be able to click on a log then have more detailed data displayed in a bottom pane.
