I had to create this custom alert and I feel should be an out of the box basic alert that should be included in the product.
SELECT Distinct
'LoginName: '+RTRIM(CONVERT(VARCHAR(50),s.loginame))+', Hostname: '+RTRIM(CONVERT(VARCHAR(50),s.hostname))+', ProgramName: '+RTRIM(CONVERT(VARCHAR(200),s.program_name))+', SPID: '+RTRIM(CONVERT(VARCHAR,s.spid))
--+char(10)+'Duration: '+CONVERT(VARCHAR,DATEDIFF(SS, r.start_time, CURRENT_TIMESTAMP))+' seconds.'+char(10)
+CHAR(10)+convert(varchar(MAX),b.text)
, CONVERT(VARCHAR,DATEDIFF(SS, r.start_time, CURRENT_TIMESTAMP))
FROM master..sysprocesses as s with(NOLOCK)
LEFT OUTER JOIN sys.dm_exec_requests AS r WITH(NOLOCK)
ON (s.spid = r.session_id)
CROSS APPLY sys.dm_exec_sql_text(r.sql_handle) b
WHERE r.status <> 'background'
AND DATEDIFF(SS, r.start_time, CURRENT_TIMESTAMP) > 600 --10 minutes
and s.spid not in (select distinct s.spid
from master..sysprocesses as s with(NOLOCK)
where s.loginame = 'domain\username') -- I use this to exclude a specific user and any multiple threads for the same spid where loginame isnt provided.
