Create a poller test function, testing each node, from each poller and reporting back those that fail any communication.
Effectively something like a port scanner run on each poller, that can extract a list of nodes from the Orion database and populate back a table of its findings
From this we could then see where the network security/configuration is stopping things from working.
Some intelligence, such as if the device responds to either (ICMP + SNMP) OR (ICMP + WMI), from all known HA IP addresses and all known APEs, then the device will be marked as a pass, but then poll known ports used by Orion, agent ports, SSH, common database and other ports used in Orion to establish if all monitoring will be successful.
This should be part of the node adding process, so that Orion checks that the newly added node can be polled from primary/secondary (under HA) and from each APE.
To have this as retrospective tool (to review those already added to the DB), would also be very handy.
The reason for this, is that we operate one Orion platform for over 40 customers, so reviewing the ACLs is not a task the network guys undertake without good reason and we frequently are unaware which network rules are
not correctly in place, until something goes wrong and we start shifting the polling load around.
Credit nust go to mr.e and his post https://thwack.solarwinds.com/ideas/9508#comment-290898
