Will "mute" be added to Trigger condition "value". I have options for Unmanaged, Down, up, warning, critical...
Trying to suppress paging on interfaces if node is scheduled for work.
A little more investigation I believe if we could select "Alert Status". I believe this is where Mute lives.
It would also be helpful if you "Mute" a parent(dependencies) the inherent dependency would prevent paging on child(s). Similar to "unmanaging" works.
