All,
I would like to see if we could display the volume status to be consistent between views of the Node and Volumes. It should be something that doesn't take 15 minutes of hoovering over every object about the Node to find the issue. It was also something I could have found much faster and easily if under Node Management Volume management was supported like it does for Nodes and Interfaces today.
Standard View of Volumes
When hoovering over volume...
Node Summary shows no issues for this Node
Only the Map view of this Node shows a Child Issue, but doesn't tell you what the issue is like it does for Interfaces, Hardware, Applications.
Derik Pfeffer
Solarwinds Training and Professional Services
LinkedIN: Loop1 Systems
Facebook: Loop1 Systems
Twitter: @loop1systems
