We have recently discovered via a few SQL reports that some of our sites were using way over their allocated Elements. The reports work fine however due to the nature of our sites we need to pro activity monitor how many Volumes, Interfaces and components they are using. I have found it clunky and annoying to have to run daily reports to find out this information and to apply the site (We use "Comments") limitation.
It would seem logical that SAM would allow use to add a view/template to monitor these individually in a table/graph and then be able to limit it via comments. We currently have a vast amount of sites, so running 3 reports for each site and then having someone spend time going through these seems a waste, when I'm sure SAM can get this info automatically for us. Then allow us to add it on a view and have it automatically refresh, track and alert us to any Components, Interfaces and Volumes that hit over a certain threshold for each site.
I know this might seem counter initiative to Solarwinds but when each one of our sites has its own IT budget, it becomes information that we need to know.
Also being able to set limits on how many elements our sites can use would be hugely beneficial, even better would be to be able to set limits on how many Components, Interfaces and Volumes they can use.
Kind Regards,
Grant
