With a multi-engine environment it would be really handy to be able to see the current engine load when moving a node between engines. When changing a node's settings from the Manage Node page I can already see whether an engine is a Primary or an Additional. To see the node count or element count or some other engine load metric against each available engine would make it easier to slide a node's monitoring about when doing rough balancing.
