There should be a chart somewhere within the tool that shows the number of incoming flows per second for each poller. It should give the same information that windows perfmon gives as described here: https://thwack.solarwinds.com/message/120012#120040
This should be built into the NTA tool so that it's viewable from the web GUI (suggest the NTA settings page where the flows per second to the database is shown) instead of having to log into the server and use perfmon.
