I opened case number 496170 for this problem:
How can I set the scanning to enable, but not to overwrite the hostname? The problem occurs when the IP address is not configured in DNS (Reverse lookup - PTR). We do not have DHCP or DNS integrated into IPAM, so when the scanner can't find the reverse DNS for the IP, it overwrites the hostname that was manually entered with a blank description.
We need scanning enabled, but do not want the hostname overwritten. |
This is being submitted as a feature request.
Please upvote if you would like to see this this feature in the next IPAM release.
