FTP Voyager works perfectly when used manually. When using automatic scheduler, it doesn't connect to remote ftp site but will connect manually. I have reviewed settings and cannot find anything incorrect although that must be the problem. Our application is the our local folder needs to access the remote folder several times per day for updates. These updates are automatically placed in an automation system that runs 24/7. I have reviewed the links in Voyager Scheduler and thy work if used manually but don't if used in the Scheduler. In scheduler, the log shows the attempt and even shows my attempt if I manually execute it but indicates execution fails. Can anyone put me on the right path to correct this?
If I can get the above working, I need the files to transfer to dropbox when the remote folder and local folder synchronize. Any ideas on this? But first, let's solve the problem in the top paragraph.
