Hi all
can you please help me with the attached debug file
i am using kiwi cattools V3.10.0 and entered the AAA username and AAA password only
What does a Putty log show as your login prompt?
Omar,
Please see this link:
login as: prompt
Hi Bykle
thanks a lot for your reply
i have applied what is mentioned at the above link but i still have error "did not receive vty entry prompt from hp"
also below is the debug output
"<NEWSESSION CatTools 3.10.0 5/22/2016 10:02:29 AM>
<PROTOCOL=Telnet>
<DEVICE TYPE=HP.Switch.Others>
<ACTIVITY TYPE=Device.Backup.Running Config>
<ACTIVITY SCRIPT=C:\Program Files\CatTools3\Scripts\Client.Device.Backup.Running Config.txt>
<USERS NAME FOR DEVICE=Ground SW>
<C OK 10:02:29 AM>
<R-10:02:29 AM>[27][2J[27][?7l[27][3;23r[27][?6l[27][1;1H[27][?25l[27][1;1HProCurve J9087A Switch 2610-24-PWR[13][10][13]Software revision R.11.30[13][10][13][13][10][13]Copyright (C) 1991-2009 Hewlett-Packard Co. All Rights Reserved.[10][13][10][13] RESTRICTED RIGHTS LEGEND[10][13][10][13] Use, duplication, or disclosure by the Government is subject to restrictions[10][13] as set forth in subdivision (b) (3) (ii) of the Rights in Technical Data and[10][13] Computer Software clause at 52.227-7013.[10][13][10][13] HEWLETT-PACKARD COMPANY, 3000 Hanover St., Palo Alto, CA 94303[10][13][10][13]We'd like to keep you up to date about:[10][13] * Software feature updates[10][13] * New product announcements[10][13] * Special events[10][13][10][13]Please register your products now at: www.ProCurve.com[10][13][10][13][10][13][27][24;1HPress any key to continue[27][1;1H[27][?25h[27][24;27H
<W-10:02:29 AM>CR:
<R-10:02:29 AM>[27][2J[27][?7l[27][3;23r[27][?6l[27][24;27H[27][?25h[27][24;27H[27][?6l[27][1;24r[27][?7l[27][2J[27][24;27H[27][1;24r[27][24;27H
<R-10:02:29 AM>[27][24;1HPlease Enter Login Name: [27][?25h[27][24;1H[27][?25h[27][24;26H[27][24;26H[27][?25h[27][24;26H[27][24;26HR[27][?25h[27][24;27H[27][24;27H:[27][?25h[27][24;28H
WFMDRetVal=1 Waiting for: "login as:"
WFMDRetVal=2 Waiting for: "Password"
WFMDRetVal=3 Waiting for: "Password required, but none set"
WFMDRetVal=4 Waiting for: ">"
WFMDRetVal=5 Waiting for: "]"
WFMDBuffer="[27][2j[27][?7l[27][3;23r[27][?6l[27][24;27h[27][?25h[27][24;27h[27][?6l[27][1;24r[27][?7l[27][2j[27][24;27h[27][1;24r[27][24;27h[27][24;1hplease enter login name: [27][?25h[27][24;1h[27][?25h[27][24;26h[27][24;26h[27][?25h[27][24;26h[27][24;26hr[27][?25h[27][24;27h[27][24;27h:[27][?25h[27][24;28h"
<R-10:03:29 AM>[27][24;1H[13][10][13][27][?25h[27][24;28H[27][2J[27][?7l[27][1;24r[27][?6l[27][24;1H[27][?25h[27][24;1H[27][?6l[27][1;24r[27][?7l[27][2J[27][24;1H[27][10;5HSession Terminated, login timed out.[13][10][13][27][?25h[27][24;1H[27][?25h[27][24;1H
<R-10:03:30 AM>[10][13]
<D 10:03:30 AM>
<SCRIPT VALUES>
<HOSTNAME="">
<PROMPT VTY="">
<PROMPT ENABLE="">
<PROMPT CONFIG="">"
please advice what to do ?
thanks in advance.
the below is the putty output
" ProCurve J9087A Switch 2610-24-PWR
* Special events
Press any key to continue "
Please upload a screenshot of your Pre/Post login settings.
