After reading a number of conversations regarding UDP and OID's I have tried numerous configurations of both UDP definitions and Advanced Alert triggers to email notifcations on failed disk or failed power supply on HP Proliant servers.
Device pollers configured for OID:
1.3.6.1.4.1.232.3.2.5.1.1.6 - cpqDaPhyDrvStatus
Historical data is not kept, options "raw value" and "get table" are enabled with format: enumeration
I have tried the format text and none, along with using SNMP type GET
Advanced alert is configured with Custom Node Poller Property type:
PollerName equal to cpqDaPhyDrvStatus
Status is greater than or equal to 3
I have tried rate and numeric status
The goal being an email on a disk in any other status than 2 (ok). Thus far any HP proliant the poller is assigned to will send an email regardless of disk health. The alert will identify the correct number and status of disks installed.
I have another poller and alert configured for power supplies, that appears to work fine with the same configuration in place for UDP and in the advanced aert.
1.3.6.1.4.1.232.6.2.9.1 - cpqHePwrSupplyCondition
The alerts send on status other than 2 (ok), and it has been tested to work correctly.
Any advice or tips would be most appreciated. My goal is to consolidate 2 or 3 monitoring systems into one, under our Orion NPM v10.1 umbrella!
