Having some issues figuring this one issue out. Our County users use a remote connection from Parallels to connect to a particular program through a Terminal Server. When a user has an issue that requires support, remote access from our help desk using DameWare closes that application. This did not occur with our previous TS connection program, 2X. Interestingly, if our support uses DameWare to log onto a workstation, and then Parallels makes the connection to the program all will work normally, UNTIL the DameWare session is disconnected, then it kills the app as before. Any thoughts on why this is occurring? Windows logs show nothing unusual occurring. The application just closes, and Parallels will try to re-establish the connection but will not be able to until the DameWare session is closed.
