quote:Originally posted by Josh Stephens First, the "NetFlow Sources" resource on the default view of the NetFlow Traffic Analyzer homepage only displays sources that Orion has received NetFlow records from in the last 15 minutes (I don't have the code in front of me, so it could be 10 mintues). SolarWinds R&D
quote:Originally posted by Josh StephensSecondly, it's possible that data is being dropped either between your routers and the NetFlow receiver or between the NetFlow receiver and your SQL server (most likely).One test that I would recommend that you run would be to visit the NetFlow Inteface Details view for one of your managed interfaces with NetFlow enabled when this interface/router is NOT listed on the NetFlow sources view to see if you have valid data in this other view.
quote:Originally posted by Josh StephensThere are a couple of things that could be causing the symptoms that you describe. First, the "NetFlow Sources" resource on the default view of the NetFlow Traffic Analyzer homepage only displays sources that Orion has received NetFlow records from in the last 15 minutes (I don't have the code in front of me, so it could be 10 mintues). If either a) the links that you're analyzing don't have a lot of traffic on them or b) they routers are configured with a long delay in between flow exports, the routers may "disappear" from this list periodically.ds R&D
quote:Exporting flows to 172.25.99.221 (2055) 172.25.99.222 (2055) Exporting using source interface FastEthernet1/0
