I am planning to install the Engineer's Toolset on to an environment that has the Failover Engine installed across two servers. I have installed the Engineer's Toolset on a single server instance of Solarwinds on our Sand-box environment without any issues. I have also done research and discovered that the upgrading of applications must be done by shutting the Failover Engine off and switching the activity to the secondary server while I update the applications on the primary. Then changing the activity back to the primary while I update the secondary server and to determine if there was any issue with the installation on the primary. Is this the same process to install a new application?
Thank you in advance,
