New to Orion. Have been put in charge of migrating our old monitoring system to Orion. I have most tasks done (it was mostly set up when given to me) and I have all our systems in one group, with subgroups for easy reference. I also have all systems being monitored to some degree successfully. But now it's time to work on the alerts, which are also mostly written. So I'm not looking too bad at this point.
Here's the issue. We want all alerts to go to an email group. No issue there. I can get the distribution group created and use that in the TO: field on the alerts. However, we also have a rotating person on-call. Depending on the person, they will use either their personal cell phone or an issued pager to receive any alerts while on-call. The issue then becomes, how do you change the address when the person on-call changes in all the alerts? I think it would be the simplest to put that in the CC: field. But with many alerts, I'm looking for a way to change all alerts with just one task. (I.E., change it in one place for simplicity and it will effect all alerts.) I'd really rather not have to tell the person when they go on-call that they have to go in and change ALL the alerts to include their number/address.
I kicked around the idea of creating a custom field, but that would effect all our nodes (120+) and be a worse solution because all the nodes would then have to be changed. Then I considered creating an unused/fake node and putting the address in a field for that node. But then the question becomes, how do you reference that field, on that node, in the CC: address in all the alerts? I even considered creating a report (somehow) where the on-call person could bring up, change the report and have it do a SQL query to update the alerts. Unfortunately, being new to Orion, this is over my head at this point.
Does anyone have any suggestions how I could streamline this?
I'll gladly give points once I figure out how to do that too. (This is my first post to the community!)
TIA!
-Gonzo
