I have tried every SQWL query i can find / create but i cant access the data even though its showing in the application monitor
Does anyone have a guide on how to do this? Thank you
@johnkush0 Is it a standard PowerShell component from SAM? If you don't want to use SWQL, just create a map showing the component/application and display it on your dashboard. If you would like to use SWQL, you could find some example here : thwack.solarwinds.com/.../swql-query-to-get-sam-application-components-values
