Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Problem with network performance monitor database
mchavan
We are using Solarwinds Engineer's Edition ver 5.0
We are facing a problem with the network performance monitor toolset.
Whenever we are opening this tool we get an error message which says "Error.Unrecognised database format c:\program files\solar......sWNet*.cfg" and the tool shuts automatically.What we have observed is that the sWNetPerfMon.cfg file which is the database file of the network performance monitor is of a whopping 1.6 GB in size.Can it be the reason for the n/w perf mon to shut down.We have a lot of interfaces listed in the perf monitor and lots of data which we use for technical audits.We are unable to view any of that now.
If we go into the database repair/maintainence mode it displays error "Cannot compact database.Unrecognised database format c:\program files\.....sWNet*.cfg and that exits as well.
Waht can be done to get our database back online as it contains huge amount of historical data which we need for audits.
Find more posts tagged with
Accepted answers
All comments
rknight
the database is an MS Access DB file even though extension is .CFG.
Maybe you could use some Access recovery tools to fix it... or at least recover some of the data.
Cheers
Ric Knight
kclee
You can open the sWNet*.cfg files in Solarwinds Directory by Access.
Use the Compact Database Options to compact the size.
In fact, I found that when the DB size is over 1GB, Solarwinds seems can't work well. So it's recommended to backup and archive old data
Alex Lee
timothy
Hi All,
I am using the Solarwind application and face the size limited problem as the SWNetPerMon.cfg file is getting biger and biger.
How to improve the performance to decrease the size of this file or can creat a new .cfg file to replace it, anything concern?
Thanks!
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
