After upgrade to 2025.2 the wireless summary view doesnt load. Anyone else with similar issue? Support case opened.
Case # - 01967740 Wireless Summary View is not loading (blank)
thank you,
Yes I have the same issue 01971355
If you search for an AP by name it still works
Hey Steve, yes that is correct searching for AP by name is working. the most recent response from support, is to rebuild the website.I',m using an AWS.
I am in the early phases of support only uploaded diagnostic yesterday will keep you posted
HP ProCurve Switches Hardening check.xmlGeneral hardening for HP switches
