I don't know if this will work or not. I've worked with Cisco to enable Layer 2 NetFlow on physical interfaces on the Cisco Nexus switch. The switch is sending the data to SolarWinds NTA, but NTA says the data does not match its template. The specific error message NTA shows is:
The NetFlow Receiver Service [SOWAPP] received NetFlow V9 flows without any template for decoding them. Configure the device device_ip_address to export an appropriate NetFlow V9 template at 1-minute intervals. See help for details.
I adjusted my 'flow exporter' command to send the data at the requested 60 second interval, but NTA still shows it as misconfigured:
flow exporter SolarWinds-EXPORTER
destination destination_ip_address use-vrf management
transport udp 2055
source mgmt0
version 9
template data timeout 60
(I've replaced the actual IPs with generic stuff in italics, just to be clear.)
I don't have this problem with other Nexus gear that is using Layer 3, but for this particular switch I have to use Layer 2. I see some very old posts here that suggest NTA can't process NetFlow Layer 2 data from Nexus, but nothing recent.
Any ideas, or am I just out of luck for Layer 2?
