Is this normal behavior to see your SAM Monitors up and down so frequently every day?
Each node may have a SAM template with couple hundred UP/DOWN status entries like this every few minutes and I'm just wondering, is it normal?
Is this an example of thresholds which are set too tightly? Its the default SQL Server template and I've tried various ; most templates with multiple monitors have these changes as I find the thresholds in the templates are always very tight for select monitors.
Want some suggestions here or is this something everyone deals with and ignores?
Running Solarwinds Orion SAM 2023.3.1
