Howdy!
I have this query to tell me when the sys admins change volume resources. What I can't figure out is how to get the date of change, if its even possible.
SELECT
N.Caption AS [Node]
,V.Caption AS [Volume]
,Round(MIN(DiskSize)/1024/1024/1024,0) AS [Before_GB]
,Round(MAX(DiskSize)/1024/1024/1024,0) AS [After_GB]
,N.DetailsUrl AS [_LinkFor_Node]
,V.DetailsUrl AS [_LinkFor_Volume]
FROM Orion.VolumeUsageHistory AS VS
INNER JOIN Orion.Volumes AS V on VS.VolumeID=V.VolumeID
INNER JOIN Orion.Nodes AS N ON V.NodeID=N.NodeID
WHERE
VS.DateTime>GETUTCDATE()-7 --Check last x days
AND V.VolumeTypeID IN (2,4,100) -- Physical RAM, Fixed disk, mount point
GROUP BY N.Caption,V.Caption, N.DetailsUrl, V.DetailsUrl
HAVING MAX(VS.DiskSize)<>MIN(VS.DiskSize)
ORDER BY N.Caption
This is an example of what I am trying to get. The code above pulls the difference in DiskSize (shown in yellow in the pic), but I also want to pull the date (in blue) when the DiskSize changed. This is pic is only showing/using the VolumeUsageHistory table. I hope that helps clarify.
Any ideas?
Cheers!
