SolarWinds version: Hybrid Cloud Observability Advanced Enterprise Scale: 2024.1.0
We need to monitor multiple instances of SQL Server, but the monitoring result is not the same, below I list my instances to monitor, could you tell me if there is any restriction with the following versions:
| 1.- | MSSQLSERVER | 12.0.6449 | SP3 | Enterprise Edition: Core-based Licensing (64-bit) |
| 2.- | MSSQLSERVER | 12.0.6449 | SP3 | Enterprise Edition: Core-based Licensing (64-bit) |
In general the SQL Versions are: SQL Server 2014 Service Pack 3 (SP3).
The monitoring result for both servers is different:
1.-
| Status | QTY |
| Critical | 1 |
| Disabled | 6 |
| Unknown | 49 |
| Up | 422 |
| Warning | 1 |
2.-
| Status | QTY |
| Critical | 1 |
| Disabled | 127 |
| Down | 49 |
| Unknown | 29 |
| Unplugged / Offline | 24 |
| Up | 84 |
Credentials used for monitoring requirements include:
- Administrator permission at the host level
- Be a member of the db_datareader role in the msdb database
- VIEW SERVER STATE permissions
- VIEW ANY DEFINITION permissions
- Connect permission to all databases, including Master and msdb
- Execute permission on the Xp_readerrorlog stored procedure
Could anyone offer some technical perspective on what might be happening?
