How can I pass simple data streams (aka PLC cycle times) from Ignition into SolarWinds, such that SolarWinds can trend, and alert on thresholds?
Any help would be appreciated.
the way solarwinds is showing data is, that it pulls data. It is not ingesting generic data. "ingest" only works for NetFlow Data or Syslog/SNMP Trap Data. If you are able to pull the data via an API Call, add the device where you can pull the data via SAM API Call or PowerShell SAM Template.
