is there a way to monitor a secondary IP without creating another node instance?
scenerio......
we have a couple sites with redundant routers, each with their own circuit. we also use sdwan which evaluates the 2 paths to the site and sends traffic over whichever path is better.
last week we had an issue with one of the circuits where it was dropping outbound traffic. our node monitoring did not pick this up since the routers are managed by an internal loopback and the polling of the effected device went over the good sdwan link. our interface error detection didn't pick it up either because there were no incrementing errors, just dropped packets. this would have been discovered if we were also performing ping tests to the public IPs
i'm looking for a way we can icmp monitor the public IPs on these routers in addition to the loopback management IP.
