Hi all
We currently have a Muted Alerts report but it is showing multiple users for the same node when it is muted. From my understanding only one person at a time can mute a node. I would like to fix this to only show the user who currently muted the node.
Here is the SWQL used to generate the report.
SELECT DISTINCT [EntityUri]
, [SuppressFrom] AS [UtcSuppressFrom]
, [SuppressUntil] AS [UtcSuppressUntil]
, ToLocal([SuppressFrom]) AS [LocalSuppressFrom]
, ToLocal([SuppressUntil]) AS [LocalSuppressUntil]
, CASE
WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%'
AND [EntityUri] NOT LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/%'
THEN [N].[Caption]
WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/Interfaces/InterfaceID=%'
THEN [I].[FullName]
WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/Applications/ApplicationID=%'
THEN [AA].[FullyQualifiedName]
ELSE 'SomethingElse'
END AS [Element]
, CASE
THEN [N].[DetailsUrl]
THEN [I].[DetailsUrl]
THEN [AA].[DetailsUrl]
END AS [DetailsUrl]
, CASE
THEN [N].[Status]
THEN [I].[Status]
THEN [AA].[Status]
ELSE 30
END AS [Status]
, [AE].AccountID
FROM Orion.AlertSuppression AS [AlertSup]
LEFT OUTER JOIN Orion.Nodes AS [N]
ON [AlertSup].[EntityUri] = [N].[Uri]
LEFT OUTER JOIN Orion.NPM.Interfaces AS [I]
ON [AlertSup].[EntityUri] = [I].[Uri]
LEFT OUTER JOIN Orion.APM.Application AS [AA]
ON [AlertSup].[EntityUri] = [AA].[Uri]
LEFT OUTER JOIN Orion.AuditingEvents AS [AE]
ON [AE].AuditEventMessage LIKE CONCAT (
, CASE
THEN [N].[NodeName]
THEN [I].[InterfaceCaption]
THEN [AA].[Name]
ELSE 'Wrong'
END
AND [EntityUri] LIKE CONCAT (
, [AE].NetObjectID
INNER JOIN Orion.AuditingActionTypes AS [AT]
ON [AE].ActionTypeID = [AT].ActionTypeID
WHERE [AT].ActionTypeDisplayName LIKE '%mute%'
I am not well versed in SWQL or SQL queries, any assistance would be greatly appreciated.
