Hi Team,
Our customer is monitoring more than 200 critical interfaces using ICMP in SolarWinds NTA & NPM.
Requirements:- They want to save two hours of ping response (9:00 AM to 10:00 AM and 5:00 PM to 6:00 PM IST) of those interfaces in a database or external source. Is there any way to achieve this using any methods or should I create a report that fulfills the customer's requirements?
Currently, the customer manually pings these interfaces in the morning and evening, which is time-consuming and requires a lot of manpower.
Requirements2:- Is it possible to create an alert for interface bandwidth utilization? The alert should be triggered when the bandwidth utilization reaches the minimum threshold of xxx megabits per second or when it exceeds the maximum threshold of xxxx gigabits per second. Can these bandwidth thresholds be set according to the customer's requirements to achieve the desired alert?
Thanks in Advance
