Hi Everyone,
Is there a way to import custom properties for 100 plus switches at one go.
any help is appreciated.
Take a look here, it should get you started if you are interested in using the API (+) Upload Custom Properties - Scripts - The Orion Platform - THWACK (solarwinds.com)
If you want to do it using the GUI you just need to create what is needed in a spreadsheet and use the Import feature under Custom Property Management.
