When a node triggers warning or critical alert due to child entities with problems (using enhanced status calculation), how do I view which child entities have problems?
I know I can hover over the name of the node to show tooltip details of the node, and it starts to list the child entities at the bottom, but...
1. sometimes the tooltip doesn't show up
2. sometimes the tooltip is cutoff due to resolution or size of browser window
3. the tooltip only shows a maximum of 5 child entities
Is there a widget that will list the child entities with problems?
Or is there a report I can run?
Otherwise if there are more than 5 child entities with problems, I have no way of knowing what the other child entities with problems are unless I resolve the 5 that are being displayed.
