the out of the box sam ssl templates do not work.
Hello @ewk.jr
Upon checking, There is no out-of-the-box template for this request however there is a workaround for this objective: If you want to monitor certificates on the Linux machines using scripts, you can try using the following: Linux/Unix Script Monitor - https://documentation.solarwinds.com/en/success_center/sam/content/sam-linux-unix-script-monitor-sw3260.htm Linux/Unix scripting in SAM component monitors - https://documentation.solarwinds.com/en/success_center/sam/content/sam-templates-linuxunix-scripting.htm Create a Linux/Unix Script Monitor in SAM - https://documentation.solarwinds.com/en/success_center/sam/content/sam-templates-linuxunix-create-monitor.htm
Hope this helps. Thank You.
